Thatās cool. Did you get them from eBay?
That company dissolved 15 years ago btw. The guy on the business card is 84
Yes sir. Thanks for the status update on the company. I think itās fair to say that these are solid gold unobtanium.
Check this out.
You tried calling the number? Do they have anything left?
Times are tough for everyone. I guess thatās whatās left after Optomus has to sell off his body panels for a battery replacement. So sad.
Is that a GX20-14 aviation connector?
Sure is
I bught every single one I could find on Ebay (that was located in the US)
What kind of active balanced are you gonna use on the other end?
Not going to bother
Im sure theres a nice story behind them.
Beautiful photo! Did you use some sort of special filter or editing, or do you just have a super fast lens?
what connectors?
Itās kinda fast, itās a Leica Summilux-M 50mm f/1.4. I also played a bit with radial filters in Lightroom
What connectors are those?
HIGO connectors bought from https://www.e-bike-technologies.de/index.php/en/
Really expensive but wanted to give them a try. Also bought them before this whole HFI thing was a reality for the Focbox Unity so⦠
Tell me more about this setup, a middrive and a hub?
You got a thread on these babies? Canāt wait for your shred experience!
Itās specs are: 12s 9p 25AH battery from recycled hoverboard packs with 12s 100A smart BMS. The drive train is a 500W rear direct drive hub, and a rewound 80kv 80100 outrunner with 2 stage reduction, first being belt and second being chain. Both are powered by vesc 6+ās connected via can bus and I have a Sony Xperia mounted to the handle bars always on the VESC app as a dashboard. Pushing 50 battery amps each, and 85-95 phase amps each. Top speeds about 28-30mph with a full battery. It seeās about 4400watts being pulled during hard acceleration, and will wheelie by just leaning back. The weird part of the design is I got rid of the back disk break so itās only regen braking in the back. But so far it works fine, even on trails.
Nice
This has the potential for some interesting tests, seeing if one motor is better than the other in different scenarios, like using the hub only when low power is required
Yeah, itād be cool to test that. I originally was just planning the 80100 but it was getting too hot and didnāt have as much torque as I wanted. It was either add forced air cooling or water cool it, or add another motor so it doesnāt have to work as hard. They both give me a pretty similar WH/mile If only using one, leaning to the hub being more efficient. I also swapped the bearings on the 80100 so thereās more drag from the bearing seals.
