Too bad we canāt get those separately
I am working on it. The baseplate that is.
Well thanā¦hopefully before I buy hypertrucks
I have a clear visor for sale if you want it
Someone put this on a Haero Bro deck ASAP!
The hero we all need.
Nice background looks sick
You guys definitely have some cool pics going ![]()
Iām bringing some calipers to Walmart next time I go
Iām worried that they would explode or something if actually used on a board⦠they look sick tho. Imagine the tread pattern it would leave on the ground if you rode through water or dirt
Be careful, those tires may be missing the bead bundle entirely. If you canāt stick a magnet to the bead then consider not riding on them at all.
Chances are itās likely solid rubber with no belt inside. I feel like it might be a hazard to dogs if they chew through and hit the metal or nylon belt, although you never know.
From the pictures of dogs ripping them up in the reviews it just seems like its mostly rubber with a bit of nylon fiber in it.
We need to convince the factory to make actual road versions on these
BTW they are 10inch so kinda huge and awesome
Shhhh china has secret plans. Youāre gonna be amazed
Thatās a āfuck meā moment if I have ever seen one. Been there done that. Good luck! ![]()
Continuing the discussion from [
Pictures and Nothing Else!](š¼ Pictures and Nothing Else! - #5807 by brown5tick
@brown5tick Yes, that is a hub motor
Mellows what ever happen to that company
Did you build the skateboard shelf
And nice collection ![]()
Yup
Thanks
Damn man I feel your pain. I hate this motor itās the worst Iāve ever had.
If you thinking about to fix this motor then forget it, save time and throw it away!
I re-glued the shaft 3 times, used different bolts, changed bearings and spent a lot of time to fix it. I gave up because it makes no sense and the shafts keep moving.
