Yup
iāve always hated how their enclosure look and also those enclosure hole is impossible to line up nicely
Nice deck
It does kind of have a mellow look to it I wonder how tall it is but their deck they drop through so it should be fine for clearance
For the money OMG ![]()
On a Bustin sportsterš¤©
https://forum.esk8.news/t/pictures-and-nothing-else/30415/5511
Holy chunking batman how do you even core those wheels like that? Itās not like you can really slide and lay down thane on a luge, so where does it go?
Itās 99% a Zenit Marble.
OMG
those are the most-chunked ABEC11 wheels Iāve ever laid eyes upon
Do they old well on 12s ?
I have no idea iām just interested because I want hub motors and me and @xsynatic @frame have been discussing if these are right for us Iāll let them put their two cents in
They completely exploded while testing the luge on the bed of their truck
I think they spun up to 80mph and exploded, they said that it looked like there was no bonding between the core and the outside, but that they normally use these abec wheels no problem. This was the first set that did that
Canāt tell you. All boards apart from the MTB only have a 10s battery.
only tried them on 10s, but i bet them can do 12s, just not sure about the amps.
the only thing i know is, 10s 40amps, 4km flat road (only little slope), 30~45kmph speedā¦when i stopped, its a bit toasty
40amp each ? I thought hub were more in the 20a range
I meant the dual makerX 4
the thing is, iāve set it as 40motor amps, but since i didnāt have metr at that time, i donāt know how much amps were the hubs taking
but they are toasty after a 4km flat road run, thatās for sure
Speaking of toasty. I just came back from grocery shopping and did a aggressive ride with maxing out the throttle often.
13°c outside (55° fub)
Now that the hubs had enough time to transfer heat all around the hub theyāre warm. So my guess is that youāll have to lower the amps in summer.
(interesting parts begin at 21:14~)
On my summer vacation 2019 in the Netherlands i used my hubs (then with 90mm wowgo hubs and old wowgo 2s hobbywing esc which was 24A i think) so hard that i wasnāt able to touch the hubs for longer than 5 seconds. Going by that and the fact that i use up to 45Amps and have 100mm sleeves on the meepo hubs, they will get HOT in summer.
i donāt remember whatās the weather temp when i did mine, but it was early june last year 10am-ish in the morning, im gonna guess is somewhere around 25 or 27°C, full on headwinds as well
