Ahah
thanks guys
Yeah the cigarette butts make all the difference
BTW rendered with the FREE Blender software
Ahah
thanks guys
u might as well fund @BenjaminF’s MR69 design instead of waiting ![]()
Last I checked, that was abandonware
probably
Has anyone done a low voltage alarm?
Assuming you have access to 2-8S from the battery use that in combination with
Problem with these ones is that either you have to find someway to disconnect all pins or manually plug it in or out every time
Will look for something that only measures the pack full voltage, might even use the arduono I have on the board already and just add a buzzer and a few more lines of code
Are you keeping your bms in a cryogenic environment by any chance?
Not yet. Trying to get the rest of the deck done in the next few days, then I’ll start a build post. Wasn’t sure if I could actually mill the aluminum pieces or not but they are done. So hopefully it will be done and moving in the next couple of weeks. Thanks
He might be implementing super conductors into esk8
Nah, I am one of those guys who likes to live dangerously by not connecting a 10 cent worth NTC thermistor.
I just moved from living dangerously… I didn’t use loctite in my screws, and there has been multiple instances when I’ve got back home with less screws than when I left lol
Both great choices. They share the same compartment size. 16s4p worth of 21700 cells can be fit inside. They’re also my two most expensive decks!
Yee of little faith…
Any reason for that? efficiency? bad engineering?
Faith isn’t my thing.
Thanks I had to torch the shit out of it
