Temp change at 120f if you must know.
https://www.instagram.com/p/CLLyqCQBZ2B/?igshid=18bt251470cp5
Donât follow me. Itâs all fake news, but itâs convenient.
What sorcery is this?
We found the witch; may we burn her?
Drunk Amazon purchase of thermal color change vinyl.
Havenât been able to heat them up enough to change the color. Sorry. Iâll do better.
I wish I still had this excuse. Now when I make these purchases at 2am I have nothing to blame them on.
Did you buy or make those XT60 mounts? Iâve been looking for those.
what baseplates are these? ![]()
@rey8801âs hammocks for caliber 2 style RKP/surfrodz TKP depending on the adapter.
Tyy
This is a massive flex
Is HULK remote
Donât call him mini
Sick mod.
I want to do this, can you make a thread with more pics? whatâs going on with the cell holder? or is there tabs and wires attached to the cell that would make sense and take less space.
Ya I make little thing later.
The cell will not be coming out, it will likely be shielded with a plastic barrier and then supported by silicone or hot glue when itâs fully finished. Charging is done by⌠well, the charging port.
did you use a 1s bms?
With thin nickel good for this stuff you can take the + terminal tab and bend it around the side to come out the top.
@jack.luis the mini remote âshuts offâ on itâs own but I guess you should.
No
The charge port doubles as a voltage checker output and as a charge port I guess
Dont feel like trusting a 0.10$ bms, and it makes da build simple enough for me
Will be using a hobby charger personally. But doesnât really matter cause that will happen once every year at the most
Youâre totally right about that, idk why I even asked lmao
np.
I think people might have the idea that itâs much more complex than it actually is
That looks sick, what bike are you using?
