The problem with the heat shrink is it prevents Flexibility in one direction.
I wanted to agree with you and I ordered tons of heat shrink for this. But I have to agree with John that the kapton is better than heatshrink.
The key is that every cell is independent from the next. It needs to flex with the deck and not have one cell pull on another. If one cell pulls onto the next, it will put stress on the nickel and the fear is that will lead to failures.
The kapton holds the cells and nickel, as well as the silicon we put between each cell and the pcb. But the heat shrink will pull cells and prevent flex.
We do have a prototype board that will be running in the coming days so we can start testing.
John did sell a few pcb batteries like this before and they are still going as far as we know.
We are aiming for $200 without a bms and $250 with bms.
Weāre debating because we donāt want to sell batteries and have people wire them incorrectly and make a warranty claim. So weāre not 100% sure yet how we will proceed.
But it will be a great deal. One option will likely be a deck, enclosure, battery, bms, metr pro, and official vesc 6ās pre wired. Just add your own drive train, set the settings, and go. Probably somewheres around $1200 in that case.
The issue is with this battery, thereās not enough space for a storm core or even focboxes, and the bms. But there is enough for vesc 6ās and the bms.
Seems like a lot of ground to cover my friend. Offering the battery with bms sounds good, but at the same time an option without the battery sounds good to save a little. Maybe offer a slimmed/reduced warranty with the battery -bms version?? Maybe that and offer an enclosure that fits well with the battery/pcb size⦠other than that most people like to pick their own escs, decks, etc.
Thatās just my view tho, and Iām not your typical buyer.
Never da less gl with the packs!
Damn man, I gotta work on everything! One good thing about all these surgeries, Iāve lost more weight! Down to 226 but I bet the majority is my muscles going through atrophy
