I think a 04b or #24 in US I think could work well on urethane.
Just a bit more loud then belts
Loud is my jam, I am totally fine with loud.
That last one broke in the middle of that garage ramp youāve been on, lucky I got a footstop done in a hurry before I started going backwards down that fucker
I donāt like to read this haha. Iām in the process of building a short board single drive having been inspired by some of your builds. Planning on running at 80 motor amps so think Iāll need to buy some spare belts!!!
That skate was running 130 motor amps.
That would have been a backwards race I donāt want anything to do with.
Think a single drive motor at 100A is dealing with more force than a dual at 100A each?
yeah wow. Ok I feel a little better
Havenāt pulled that much double. Maybe it was the powah.
IMHO yes, because while you might have a dual drive turned up just as high, itās rarely used that much. The single drives I will smash the throttle & brake 100% like, all the time. Sometimes Iāll just be surfing on a locked up rear wheel half sideways as I come to a stop, because itās so much fun. The dual drives are more likely to not be run at full power as often in actual real-world use, and locking up the rear wheels also means you canāt steer anymore, unlike single drivesā¦
True. There are few times that I can pull 100A each over a ride. Usually two or three times over 20-30 minutes.
Shit, I assumed it was snow/ice, forgot about the ridiculous amount of power youāre throwing through one motor.
Saw him live at the Bammies. Better dancer than all his pro backups.
Eeebum babum beebum de
Bahum bahum bee deedum bahum
Beedum de bahum bahum
Bee deedum bahum
Scooduliyabum beedum
De bahum bahum bee doo
Haha, nice, wonder if heās still remodeling homes(in Florida i believe)
Hey @Venom121212ā¦donāt you need my permission before posting video of me with my awesome build?
What BMS is that?
Thatās an LLT SmartBMS. @ApexBoards sells them in the UK, and @thisguyhere sells them here in the US.
Thx. Any idea what those bolt connections are called (the ones on the DieBieMS) and can you connect them to any BMS
They are called ābush terminalsā, and they require a PCB specifically designed to accept them.
yep apex customs
amazing service got here next day
spent the past hour cutting nickel with my bro
cut 50 long pieces and around 100 short strips plus had to curl them
my fingers are blistered all over
