Is she hot and single?
First this one, but pls donāt dare to buy anything from this scam company, they sell this $20 glue gun put their label and sell for $100
Then I watched this one mostly to see how to derive one part from another in f360:
Iāve also watched this one as the youtube algorithms kicked in:
One more thing to add is that you will be better off using aluminium mould as my resin one has no capability to conduct heat and so I need to wait few minutes for it to cool down.
Also you need decent glue gun that has a lot of thermal mass and high amount of molten glue that is held in it, Iāve used Bosch PKP18E, scam company uses Tec 305-12
And ready to mingle
Fixed it and even painted it for you! Nice
What baseplates are on the hummies?
Paris 50s. Bushings could use a swap, bit soft and not responsive enough for my liking.
I think we need a blown esc porn threadā¦
Holy shit bro, you blew the lid off the DRV and even scuppered the MCU as well
Did you try turning it off then back on again?
It fizzled and arced and i then i zoomed it again for science. When i dropped the back wheels onto the ground there was another big pop
I do molding and casting with plastic/rubber shit as part of my job. If you ever want to talk shop, let me know. Impressive first casting btw!
Looks like it just needs a cleaning and maybe a usb upgrade. Everything else looks like it was ran cool.
Noice. Are those Flipskyās with 10 or 8mm shaft?
The gear drives had a 10mm pinion, so I had to buy the 10mm shaft motors
I see. I donāt think the 8mm shaft ones fit 8mm pinions because of the stepped part but I was hoping to be prooved wrong
wait, are the hummie hubs out ?
beautifull build !
What are those wires on the front trucks ?
Looks to me like he is using an XLR for his charging port but I am not 100% sure about that.
