I played a bit with the “hugly box” option, and now i’m waiting to salvage a connector board for the exway hubs to try the “carbon fibre and lipo” version
I agree with Brian. There’s no point, when you’re riding, the key fills the hole. When you’re not, if you must, you could 3dp a bung to fit in it when it’s not in use.
I see no reason, also the female end is much harder to mount because of aforementioned reasons by Brian
Gah. You’re right. I can’t see to find any ready to buy xt90 panel mounts
They’re right here
I’m really liking the look of this build. What deck is that and size? Cheers
I’m like 90% sure its a Landyachtz Rally cat, correct me if wrong
Rally cat has front and rear tail IIRC
The name of this one is on the tip of my tongue…
It is the older style landyatchz Rally Cat.
I think the 2020 version is a bit narrower.
I did drill out holes further out to extend the the wheel base a bit because of the enclosure I used to have on here.
It is a neat deck.
Will regular tabletop epoxy do?
Yes, of course. I’d stay away from “fast”, “quick”, or “5 minute” varieties though. Those are all red flags that their engineering goals aren’t centered on high quality end product.
I grabbed some 2 min stuff before. Completely useless unless all you need is one scoop. The batch was a gelatinous blob by the time I went for a second scoop.
Is that 42"? I don’t see a size listed.
My boards only a few months old and doesn’t seem to be holding up too amazing. It’s still a phenomenal board I love this thing for sliding and pushing around. I’d love to ride this board as an esk8 I’ll be on the lookout for your finished build for sure.
Dude.
I swear I saw the dimensions somewhere but can’t find now.
Pretty sure it was 42 x 10, 33wb
Same as she regular camo 42.
I wonder if it is the same exact deck with just a different graffic.
Ok found where I saw it.
It was instagram…
https://www.instagram.com/p/CJWb42NhftC/?igshid=g8fkcc8cghzu
Someone else with TB130s. How!?
The better questions is whyyyyyyyy
Haha. Well I presume you lucky few are testing them out to see if they hold up . Just jealous really haha
Tell Dex to send me a pair to test out as well
