How does this work? That isnāt the esk8 remote is it?
It looks like a garage door key fob lmao
@PixelatedPolyeurthan @ShutterShock I believe itās a simple screw in circuit with four relay outputs and a fob remote to control them. I have one somewhere in my stuff
Nice haha Iāve got mine on my Maytech v2 now but thatās good for other remotes
Nope, itās a separate remote, but I will try to integrate it into the esk8 remote at some point, this is the one I bought
ISK 436 60%OFF | GERMA Universal Wireless Remote Control Switch DC 12V 4CH relay Receiver Module With 4 channel RF Remote 433 Mhz Transmitter
That reminds me that I might need one soonā¦changing to a Bruce remote on my monster. So gonna need light control. I think Iāll try to make a small portable case with the head light screwed to the top and a similar circuit inside with a car booster powerbank
LOL. opened the link to see ābuy again?ā pop up
Guess thatās exactly the one I have
Thatās really really cool, thanks!
Wait, do you actually power on from the remote ?
I also power on from my remote, but I use an external relay.
Edit: nvm, should read words on pictures more often
Yep it does, and after I blew up my first receiver, now I know how to NOT wire it.
@Venom121212 Iāll write a post in my build thread about it tonight hopefully, I have it working properly now but I was waiting because my first headlight bracket failed. Iām using the relay on the receiver though like Plurf was asking
Triple press to turn on, triple press to turn off. Interestingly there is also a transistor switch but that isnāt strong enough for my use
Is it also a matter of using a series of clicks of a button?
Yes it is, four clicks will turn it on and off if I recall correctly. Thereās only one button on this remote as itās meant to be waterproof
Hmmm I donāt like the idea of triggering something wile ridding, where is the button positioned ?
What does it normally control?
Having to click multiple times is a bit annoying. I click my 2nd channel once and itās on, once again and itās off. Simple ![]()
Thatās pretty much impossible, you have to press it pretty hard.
@Flasher there is only one button on the remote, so it controls all functions
Thatās my question
example: 1 click=? 2 clicks=?
1 click changes telemetry data shown
2 clicks changes speed mode
Correct, and then three clicks turns on and off the relay, four clicks turns on and off the transistor switch.
I may be thinking wrong for the switch because there is a long press as well. Canāt remember what that does. Would need to check on the remote itself
