I think that if he really did his best he could fit another oneā¦im quite disappointed he did not
do you have a build thread?
Nope. What cha you want you know?
Which 3dServisas drives are those? ratio? do you have the option to switch to thane? also what is your battery config?
I am considering a build with the mini urethane drives with the bergmeister adaptor so I can switch between bergs and 110s. Iām concerned about whether there would be enough torque when running the bergs. Ideally my battery would be 12s4p p42a.
@CiscoV can correct me if Iām wrong
https://shop.3dservisas.eu/collections/drivetrain/products/fatboy-ss-mini-gear-drive-v4-for-fatboy-230-240-260-trucks
He also said theyāre 3:1 ratio.
I would assume with the appropriate adapter. Which is something I havenāt looked into, so wouldnt know (primarily pneumatic rider).
20Ah 12s8p 25r double stack 120a
3:1 on bergs has pull on 12s. Especially if you up you motor amps to about 50a per motor. I run mine @ 45a per and love it.
However lol, 3:1 on 110mm is going to be fast lol. Pad up brotha
6355 class motors can haul some ass, and they are light. Underrated in my opinion. Iāve all but stopped using 6374s. I run dual 6355 or single 6380+
Nope. These are pneumatic specific drives
No compatible with thane ā
ā
There is room for 4 more, Iām certain. @ahrav
Jus gonna put three of these in there
https://www.maxamps.com/lipo-22000-8s-29-6v-battery-pack
I think āold grouchyā makes her point with these if Iām not mistaken (@MoeStooge)
⦠wait, three?! Weight starts to matter man
[Screenshot_20200912-092159]
That album is my jam. The whole thing, beginning to end
I run two of the Max Amps 8s Bricks in Grumpy with room for a third. The two bricks in parallel deliver 400a without sag and approx 40 miles range @ 30 Wh per mile. The quality is really good on these.
What enclosure did you use for this deck?
[20200913_005208] [20200913_012937] [20200913_013159] [20200913_015026]
Is that your cat ?
Is that your cat
Better question, how did you turn it into a caterpillar?
Seriously Iām tripping
black cat
to Caterpillar isnāt that like bad luck to good luck thing IDK
Hahahaha burn the witches!
Nah its a stray that always hangs there. Whenever I skate past that area the cat will always jump out.
[JPEG_20200912_174529_4495491906969830102]
Itās hilarious that youāve blurred-out the EUC ![]()
