Howâs that even possible?
whatâs the enclosure bro?
Yeaaa⌠how. We are losing our shit over here hahah
Took off a good bit of the hub lol and drive.
Yeah. But did the bolts just break loose and fell out?
Yeppp all of them came undone and then just straight rubbed all the rest of the material off hahah
But itâs okay. @Arzamenable fixing everything as usual
Damn! That suxs. At least you didnât eat it lol
Dude! He was still hitting 40 plus in the darkâŚ
@ahrav so what happened to the keyway and gears?
Weâre those loctited? Everything loctited on my board came undone today⌠I think the heat + moving makes just enough airflow to keep it solid but if you stop after riding it hard itâll blow up
There are no keyways There are 5 bolts that put the power down to the wheel. Those break loose and fall Therefore some PM is always a good idea. It only takes a second to randomly check your bolts. Specially if youâre planning on doing 40plus
Lol faaaaakkk. We heard this crazy ass noise. I thoughtnit was like the nano drive and he maybe had a loose gear on the motor shaft. We were only about 3 miles in on the 14 mile ride when we heard the issue
The bolts on the hub just came undone and it was just grinding away at the hub and the gear lol
Gear shaft stayed in place so thatâs good
So youâre saying that noise wasnât normal? Lol
I mean⌠hyperdrive
Hahaha yeee we was riding blind. I was just racing cars on 3 motors
Kinda confused still how it even happened tbh⌠do some dissection when I get home.
Pretty sure top one is the old one.
Also have new one on way from sk8kings, so will confirm in a month when it has traversed the globe to me.
Slightly taller variation of this 3d print @dani
Designed.
https://dosimplecarbon.com/making-super-nice-3d-printed-esk8-enclosure/
Thereâs also this version thatâs taller and reinforced
To me it looks like you didnât put them in at all.
Gotta wait for 3ds response.
I thought about it⌠but I wouldâve noticed it. Because as soon as your brake the motor spins backwards and you can feel the vibration throughout the boardâŚ
And that didnât happen until maybe 10 or so miles into the ride.
Worst comes to worst I buy a replacement hub and back to the streets we go
Weird. These bolts donât need to be that tight either. I usually just finger tighten them + 90 degrees.
