So THICC
whereād you order those?
I got hooked up by @TinnieSinker . I have no idea where it came from originally.
Cheers, itās the first time Iāve used fibre glass, so not bad for a first attempt
Oooohhhh Boy ![]()
Gimme gimme gimme
Did you run some strength analysis?
Sure, Iāll get it on my blog soon.
Still playing with the bending tooling though
Shame your guysā mounts arenāt interchangeable.
@Mikaelj has short mounts for Surf Rodz TKP
@XTLA has long mounts for Surf Rodz RKP
I need long mounts for TKP ![]()
I have long tkp, as long as your flat to flat hex was 19mm
Actually i only make a very little quantity of tkp for my self, but if some really needed longer plate, i can share
Hmm, I havenāt ordered the hex hangers yet. How good is my chance of getting them to fit that size? 50/50 ?
Edit: read your thread, I can sand them down if itās too thick. good news then
Easy fix, rubber heatshrink if it loose, sand it down if too tight.
I would not call surfrodz tkp for precision trucks, but at least they are price worthy.
Agree
where did the other part go???
I think it was stuck on a bolt on pulley it seems from the indents in the wheel.
Love waking up in the morning to some wood
I miss everyone but @BillGordon the most ![]()
PLEASE tell me this isnt true @kevingraehl
If itās true I need to replace a BMS asap.
edit: This is what I have. It claims to have balancing
If its bigger than the tiny one you might be fine. Heres the original refrence
