I have given that a fair bit of priority.
To me a slimmer build is often nicer looking.
Looking back at the @whitepony days. It think keeping it clean & slim was I think was part of why his builds looked so nice back then.
I took a crack at building the lightest 2wd mtb possible. The compromise is you get like 15 miles of range max, but still⌠27 pounds is pretty crazy light.
If you put an acceptable range battery in it (20s4p), you also have to go with a larger box, and then youâre at 37 pounds, which is not so light.
Anyone see a place to cut some grams?
| weight | count | total weight | ||
| Prototype Mtb Deck | 2200 | 1 | 2200 | |
| 18s2p battery (583wh) | 3200 | 1 | 3200 | |
| radium belt drive kit | 283 | 2 | 566 | |
| newbee rtkp | 751 | 2 | 1502 | |
| Flipsky 6354 140kv motors | 460 | 2 | 920 | |
| MBS T3 tires | 235 | 4 | 940 | |
| inner tubes | 80 | 4 | 320 | |
| Hubba hubs | 193 | 4 | 772 | |
| Pelican 1120 | 607 | 1 | 607 | |
| mbs f5 bindings + heel straps | 580 | 1 | 580 | |
| Bearings | 20 | 8 | 160 | |
| ESC | 330 | 1 | 330 | |
| 12.1 | Kg | |||
| 26.7 | Lbs |
Possible changes
Rockstar ii hubs
Junction box for battery box
Thats not bad. Lipos are a good option for low weight I think they have higher gravimetric energy density than li-ion and youâd want the discharge with a small pack.
Are matrix iii lighter than newbee rtkp?
Matrix iii are a few grams heavier
I was surprised to learn this, but lipos are actually significantly worse in terms of wh/kg vs lithium ion cylindrical cells. The reason some people still run them is the high energy delivery with less sag compared to cylindrical cells.
- p45b = 231 wh/kg
- normal lipo packs = ~150wh/kg
The place lipos may be a good choice is if youâre tight on space. If youâre building a brick pack, the wh/liter for lipos is better. If youâre building a stagger pack, the wh/liter is better for lithium ion cells.
@ducktaperules did a fantastic write up here on wh/liter:
and batterymooch has this to say about lipos
What are the battery dimensions plus esc (everything in da box)
Or rather, whatâs the max size needed to hold it all
Fivestars are 164g a piece vs hubba
On the topic of weight reduction, things like deck material, thickness, battery power to density, motor weight and even wheels will make a difference. One of my builds that i originally built for stealth, ended up being too heavy when i did a 10s3p, shouldâve done a 10s2p instead as the deck contributed a lot of weight.
mtb with hoyt 5in, if u can steal those nylon version off @BenjaminF
also titanium everything, ask @poastoast how much weight he saved when he went full titanium
Something like an end grain balsa-cored composite deck can be half the weight of a conventional wooden one, but IDK about longevity of something like that.
Pelican 1120 looks like the ideal jump pack size. You can fit a 18s2p p42a pack, or a 18s3p p28a pack. In both configs you end up with basically identical weight (2520g of cells) and 544wh. Imo 18s2p of p45b would be the way to go here. 18650s are stupid expensive for some reason.
The 18650 config would give you an extra 5mm of space on top, so that might be useful if you were trying to jam the esc in there too.
Slightly larger junction box I found is 440g. Not for everyone but mine have taken a beating and havenât budged. Worth considering if you want to go ultra light maybe ![]()
200g off is significant. What is the box?
LeMotech Waterproof Dustproof IP67 Junction Box DIY Case Enclosure Gray 7.9 x 5.9 x 3.9 inch (200 x 150 x 100 mm) Amazon.com
Just one example.
âDIY junction boxâ is the key search term
I think wheels are the most worthwhile component to tackle weight on since it is directly related to acceleration and braking. Tomiboi has a nice set of hubs out there made of fiber reinforced nylon. Maybe a carbon reinforced nylon or thermoplastic? Also, hubs look like they have material on them that could be whittled away while maintaining good strength and durability.
Trucks are probably another good place to focus on for weight savings. If you look at the Stooge 3-link truck, for example, the hanger/axle is a solid piece of steel. May be hollow steel axle with a 15mm or 18mm diameter would be lighter and stiffer.
I think the high quality components in the bicycle industry have lots of weigh-saving solutions.
Rockstar nylon hubs are 165g each, and are adequate. Matrix IIs might be lighter with the nylon baseplate (IIRC each nylon baseplate is 115g lighter than a metal baseplate). F5 bindings are pretty chunky compared to the cheaper foam/nylon ones, although youâre trading off weight for comfort. You could also probably save some weight by shaping the deck a bit, but thatâs starting to get to the extremes.
Hereâs a question Iâve had for a while, and this seems like a good enough place to ask it.
Is there any avenue where more smaller motors results is less weight than fewer larger motors, for equivalent speed/power?
And what are the big factors that push things one way or the other?
I think it really depends on how hard you want to push and what kind of riding you plan to do. Larger motors can handle more amps and generally stay cool better. So hilly, high sustained speeds probably fair better with larger motors. But if youâre mainly cruising not doing heavy hills or acceleration I think you can get away with smaller motors.
My own observation. I think 4x 6355 motor are more than enough for most things. But is that lighter than 2x6385, not sure.
Certain motors can handle more power than others. I had a pair of Reacher 6455 motors with 70 amps that had no issues. I have hear of reacher 6485 can handle well over 100amps. There is some room for weight savings in the motor department.
I wonder if titanium instead of steel gears would work for pulleys and gear drives.
I keep my boards simple, which is lighter. BUT, I really donât care about weight. I do care about trueness, balance, and stability. I find that I compensate by HYPERMILING. I anticipate stops and starts. Start off slow and brake slowly. Maintain my momentum.
Weightâs a pretty big deal on an MTB though because the bindings let you jump and lift the board around. Jumping a 35lb board is significantly harder than jumping a 17lb board, both in the strength needed to lift it and controlling it in midair.
