Random Great Deals 2020 [Serious]
It’s only 57.6V fully charged :wink: You could filter voltage spikes if you really wanted to.
I don’t have any docu of the A123 build… I built it over many beers w/ a neighbor and they split last week and I haven’t heard from him. My first round cell battery pack build, and not my proudest work. We just welded twelve 3P groups, folded nickel between them, double strips on the outside series connections. Didn’t spend the most time on construction bc he didn’t give a fuck and I was mostly there to get some weld time in. Didn’t even shrink wrap it, just a crap ton of kapton, but it ended up just barely squeezing into the cutout width wise (shrinkwrapping would likely require sanding to remove a mill or two) and it was <500mm long, leaving enough room for the bms and maker-x dual. Pretty sure another P group would fit in place of the BMS np.
Trampa offers 10% on everything bought in the COVID time (Not sure how long the timeframe is though)*
*bought items are shipped AFTER they can get back to the shop and the carriers give green light.
Code : 12345678
15% discount on everything :slight_smile:
Shipped as normal
code: STAYATHOME
This Ebay listing for HLG-150H-48A is likely the best deal for an adjustable 12s 3.2A charger ever. MeanWell makes high quality efficient stuff - this charger does does not need a fan because it is 93% efficient.
Both voltage and Current are adjustable. It is CC/CV. Read the Specs.
Tip: Shipping is much more reasonable if you buy 3.
hell yeah just bought one.
Trampa have some vesc6 on there clearance corner (refurbished) for £125 a piece
If you need a 12v/24v PSU for your balance charger or boost charger, this is hard to beat: https://www.ebay.com/itm/264727758403
(Only for those who actually know how to DIY build a Charger. This is not plug n play)
Edit: here is what you’d have to do to make it work: https://www.youtube.com/watch?v=d7lF1sIgIlA
@BillGordon can we merge this thread with the Good Deals Thread? Or that thread with this one? Or just close one? Having two makes my balls itch.
Yeah that’s the cause.
Well the lice probably dont help but im putting a solid 70% on this two threads business.
Just shut this one down, all the deals are expired probably
Please use the “Good Deals Thread” going forward:
Thanks, all.
