Im just curious if dickyhos motor mounts, https://www.ebay.com/itm/CNC-motor-long-reverse-mount-for-50-63-motors-for-DIY-eskate-electric-skateboard/303147648254?hash=item46950204fe:g:SvMAAOSwoMZc0x4m fit TBs 160 AT tires with 410 mm belts ideally, I really want to love BNs but id have to get new belts and other things to use them properly so its making me think I should refund them and go with Dickys.
What other things? Belts are not very expensive at all
I’d go BN over dickyho
do you have a place to order 395 mm belts from I couldn’t seem to find any reliable sellers. thanks!
They should work fine, the long motor mounts have 95mm center and the TB wheels are only 62T so there is plenty of room
Also dicky should be able to provide any belt length you need
Are you in the US? There are tons of belt sellers
vbeltguys
vbeltsupply
there’s more, I’d have to look
Indeed. These guys have everything, prices aren’t too bad either.
There’s a syntax for their search bar, but as you type things will pop up. If you’re looking for 280mm long 12mm belts for htd5M pulleys for example you’d start typing 280-5M-12 and you’ll see your belt before you get done typing.
pretty sure everyone here is using 5M.
Thank you everyone! will stick with BN’s mounts and order some new belts!
