1: You don’t have to screw anything into or through the wheel
2: No more broken cores from screws going through the wheel
3: They take 2 seconds to install
4: Many have a support bearing, which is stronger
5: The wheel can’t come off because the axle nut holds it all on
Hi, anyone know whats going on here. Bought these pulleys used in a package with the whole drive train. After taking everything apart I noticed the pulleys pins are shorter then the example I bough for my single drive. Also they seem to be bent. They have a lot of play in my Caguamas. Any tips how to replace them and where to source replacement pins. I have unscrewed the little screws holding them in place but they seem to be glued in or pressed in additionally.
