LMAO
Edit: But seriously, how come 2kWh are not enough?
LMAO
It’s the folk that grew up with 3310’s. Look what google and apple did…
Has anyone tried a layer of glass reinforcement on it before?
I have a kaly enclosure laying around my house, but I don’t know if I should use it now…
what is it with these pro builders and thier shitty enclosures lately
wcs enclosures crack on command. Now kaly.
Ppl bitched about EBS/flux going with ABS for the new enclosure. It’s 5mm thick and sturdy as hell, still keeping an eye out for the first failure.
When its that damned thick its fine. It just has to be that damned thick to work lol
Also a lot of people overtighten their enclosure bolts so that’s why ABS enclosures failed for them. I remember one dude complained about tillers abs enclosures cracking and when I inspected his board, he didn’t even have washers for M3 bolts like bro, you’re dumb
Order if you find a thick enough gasket. 12s15p 30Q for that 45Ah good good
Agree 2.0 or if you buy an enclosure from him are abs and pretty thin vs the flux enclosure.
Mine are cracked from just attaching the enclosure to the deck lol
I’ll build you a flux that would murder either of them and look like candy coated orgasms while doing it.
Burnt Yellow with Dos XX glass frit of course ![]()
Biggest flaw I see with kaly is that abs enclosure. IT WILL CRACK ON YOU
I’ve seen countless of his enclosures cracking up witch is not necessarily a bad thing but it’s a little bug that most peep aren’t koo with.Idk why Ernesto hasn’t done anything to improve that. He should be on fiberglass by now imo
In the old forum this guy from New Zealand (forgot his nick) created his own silicone enclosure for his Trampa DIY. Really flexible material as well as durable and protective. That maybe an alternative construction technique for all the type enclosure cracking going on.
Hey — are those the lacroix smart tail lights? What are those mounts for them on the lacroix? And how did you mount them on the truck bolts for the flux?
ask @Brently, it’s his build
@Brently yoo
What are those mounts for your tail lights?
Flux=way better then proto.
But I’m 6-5" tall and weight a ton.
No more heels scraping on tires.
Also no more range anxiety. I actually have never run my 50e 12s9p flux down.
those are aliexpress specials
Can’t find the link right now but if you search something like, “double skateboard rear light/tail light” it should come up. Comes with a bracket to mount and everything.
They are motion sensing so they’re pretty dope for night rides or if you just want ppl to know when you are braking.
from my build thread for her -
edit - found the link homies:
https://www.aliexpress.com/snapshot/0.html?orderId=8018015434602261&productId=4001198292870&edm_click_module=order_detail&tracelog=rowan&rowan_id1=postArriveV2_1_en_US_2020-08-25&rowan_msg_id=2261801801543459$ce4ba32608894f75a486ac096900b153&ck=in_edm_other
They raised the priced on us - think I got it for $30
Thanks!
Oh fuck I’m buying these
dude they’re legit and cheaper than the price on Amazon
