already know the price, the specs, and what it can do
too many praises and review
tho wanna see dissection video
Would be neat to see someone disassemble it
I want one lol they’re cool
There’s not much too them really, most of the stuff you see from the outside is the stuff to see on the X4S
Well the Endeavor is quite different, no?
X4s is like bajaboard, the endeavor seems more unique. I think it would be interesting to see how they routed their power, how the battery is built and stored, etc
We m supposed to be getting an endeavor so I’ll do it. I thought you were referring to the X4S
Oh nice! I’m not sure what soketsu was talking about but I was talking about the endeavor
it’s a 12s
I only worry about parts durability
But for now this board looks like a game changer
I didn’t shoot the video, but I measured the turning diameter of the turn.
When turning while standing, the diameter is about 10m. This is about the same as a general passenger car.
It was about 8m on the grab deck.
After purchasing, after running for a while, the front wheel bearings started to make strange noises according to the speed.
I replaced the bearing with 6001LLB.
The charger broke after 4-5 uses.
Now I’m charging by disconnecting the XLR plug and converting it to a DC plug.
That’s all I can report now. There is no problem so far when using FSESC4.20 with 12s, Batt.MAX40A.
Hello everyone, I am new to the forum and look forward to the delivery of my Endeavor S propel.
I am thinking in the future to modify it by changing the ESC and adding a battery.
I would like to couple the existing battery to a second identical one, but I cannot know that it is the one delivered with the indication 12S3P 666Wh.
I would also like to know if there is room for a second.
Knowing that I would like to start the 2 batteries at the same time.
If someone can take pictures of the frame with the interior and dimensions that would be great.
thank you
I don’t think anyone on here has an endeavor S but once someone does they’d probably be willing.
lmao the actual cord broke?
busted bearing and busted cords so early in the game…
did they go dumpster diving for parts?
A plosive sound was heard from the charger body. The cable and plug are fine, so I cut the cable and plugged it into another 12-second charger.
If the S and Pro frames (enclosures) are the same, you can probably increase the number of cells up to 12s6p.
If you move the remote control antenna to a position that does not interfere with the battery, 12s7p may be possible.
I also considered buying an S and modifying it, but I bought a Pro because it was a hassle.
The dimensions of the Pro 12s 5p battery are approximately 510mm * 107mm * 47mm.
This is a broken YZ POWER charger. The fuse is not blown. I’ll throw it away soon.
Maybe I was just out of luck.
Hm weird yeah we typically recommend YZPower for chargers, so they have the right idea
Maybe you just got a bad one, unlucky. I have four and no problems with them
The propel team has been pretty active responding to questions on Facebook and this has been addressed several times. The S and Pro have the same enclosure, put the pro had a larger recess in the deck to allow for more battery room. You’re going to have more trouble attempting to upgrade an S model.
How is the suspension / truck system holding up so far?
What kind of riding have you been doing and how many miles?
I pre-ordered the S model, primarily for the suspension + integrated belt drive system, with the intention of replacing the ESC.
Once I get a good look at it, I will also pursue a larger battery, custom enclosure, and a custom board.
