I have built an electric bike using the 75200 vesc and 80100 7000w motor I am running it with a reliable 48v battery pack. I ran the set up wizard and the motor spun up great with the settings looking as expected. When the motor direction was confirmed it osolated and didn’t complete a full rotation. I set up the twist grip throttle but I got the same result.
It would also be good to know what sensor mode you’re using; sensorless, hall sensors, or one of the HFI options.
Oscillation as you mention sounds a lot like what I was seeing with my 80100 motor whenever I attempted one of the HFI options. I also couldn’t get the motor to spin reliably using speed or position control methods (until I installed an encoder); only the duty/current control methods worked. Not sure what method your twist grip throttle would use.
Thank you very much I reset the firmware and I have managed to get the motor running with help from everyone on this page I will definitely be back if I have any further problems or questions. Can’t thank you enough.
