Can I also add your impact test only bashes the middle of the core in use stones hit the edges of the wheel and twist the core applying a different force thro the core witch could be worth investigating.
If you use the @ in front of people names it will tag them for you
isnt that only really a problem with budget / or ripoff wheels ?
i only used genuine abecs in various sizes and they all worked flawless - also never seen a cracked core on them
that being said i moved on to kegel also with the tb wheels, last set of abecs sitting in a corner shamefully
Which brings me to the iwonder point⦠since it is not a genuine abec core, the problem now is not fit and finish, but structural integrity and material stability. I can safely assume this wont happen with the kegel design using whatever material they are using. The definition of insanity is doing the same thing over and over again and expecting a different outcome - literally flogging a dead horse here
I wonder why a reversed Kegel core pully was designed OH YES, KEGEL COPPYS
Aluminium has a stronger strucal rating than steel because it can flex when steel equivalent shiers. Rigidity is not proportionate to durability in engineering it is often the opposite
Kegel core is not supper itās different has different advantages and disadvantages iv seen more broken Kegel pullys than ABEC. Iv seen more broken Kegel pullys than broken I wonder cores. Your points are unfounded and with out merit or fact.
Aluminium stronger than steel? Though irrelevant to this conversation , thatās the first time i have heard of this⦠lighter yes, but stronger? Is this why aluminium bike frames have to be so fat and steel can remain slender and thin?
Back to the topic, my kegel pulleys have the full 10 spoke design and is done in some strong plastic polymer material. Broken kegel pulleys you refer to are most probably the 5 spoke design which should probably explain everything. And maybe you are right these potentially broken pulleys should be in some other material other than steel in terms of the types of forces required to handle
Shearing and bending are basic forces calculated in engineering all the time aluminium is better at counteracting shearing forses steel better at counteracting bending forces.
Come on now⦠donāt be pulling out the race card just yet! It is a valid discussion⦠more than just a bunch of numbers this be. I donāt wanna wake @BluPenguin now either - heās also a keen salesman for the Abec cores⦠but his take is more of looks, at least he admits it.
I can only guess but I imagine doing things wrong or with the wrong tool. seen bent and sheared pins in pic on the other forum. Canāt say I ever managed to do it my self. How often do people use a puller tool on the top lip instead of placing the arms all the way over.
