Problem with Slick Revolution/iWonder Cloud Wheels (SERIOUS)
It might be a 3D rendering. The radiating fingers inside the tire are black instead of the white fingers that appears in all the cracked wheel images in this thread.
By the way, what is the function of those fingers? Do they stiffen the tire at the centerline to reduce the rolling resistance? Or is it reinforcement to anchor the foam to the core?
I think Boa said they have a wheel version they are making with a tread pattern, for all sizes of their new wheels, could be worth checking out
There’s smaller dia torque board wheels available with the same stuff the 110s use
Ya… telling me… This whole time you didn’t even know those ā€œfingersā€ was the foam core???
And there is a clear/black option instead of grey/white…
I’ve only seen close up pictures of broken I-wonders. Are you surprised I have not purchased a set?
Anyway, sound like the clear portion is solid clear urethane and the fingers are pockets of a light resilient foam. Seems clever. Too bad they can’t mold a reliable inner hub/core/bearing sockets.
Curious, have you ever ridden a set of cloud wheels?
I have not. I was thinking about purchasing a set, but I was going to borrow a friend’s set to try them out first. Then I found two different threads on broken cloud wheels. I found the thread intreaguing because initially there were so many people who said they were going to keep riding them despite the failures.
To me it looked like there was a clear urethane tire surounding a clear foam inner tube with some opaque finger structure to bind the foam to the core. Now I know differently.
Another statement from iWonder
Facebook link
I’d just like to point out if they’d ever just gone kegel, they’d never face such problems. M2c
Yeah but then they’d have uglyass wheels and that’s just not okay…
I’m stoked they decided to keep abec and switch material suppliers and core design to thicker spokes. Although they skipped over to mention the batch of under injected cores, looks like the next batch could be solid.
That’s just you…
What’s wrong with market variety? If you like kegal the tb110s are great wheels that rides just as smooth as clouds… I don’t get why everything’s gotta be the same shit
I would prefer Kegel, but a proper ABEC style would be totally fine.
nothing wrong with market variety, but I’ve personally had a myriad of problems with Abec cores, and I think that they’re ugly. I’m with the less is more crowd / KISS principle.
meh. So are transparent blue wheels but I’m not whining in that thread lol.
we’re arguing over personal tastes. Like you like potatoes and I like quinoa sort of argument. We should stick to engineering.
I do like potatoes. How did you know?
Good point tho. On topic I think the new core is still PC/ABS… I’m not aware of TPU that can be made crystal clear… But maybe ā€œthicker coresā€ just means ā€œwe figured out how to inject plastic properly and account for shrinkageā€
From the picture above, it looks like they switched to abec clone style cores rather than genuine ABEC cores with the thinner spokes.
Which is ironic because the cores were splitting vertically, not across the spokes… Aside from that one wheel that came apart, none of the other ones had broken spokes, only cracked bearing seat
iWonder update via facebook… looks lithe theyre switching to a thicker core with the ā€œdiscoveryā€ model and the 105mm
