Ha. Just a collection of “frequently asked dims”.
Hmmm, all the important bits are there. The arc degree may be a little extra. 360/5 lol
The Tri-spoke is a little more difficult. It’s older and there have been a few molds over the twenty years it was around (discontinued now). Generally speaking it’s three 6mm holes evenly spaced on a circle with diameter between 60-62mm. In other words, you’re better off measuring
Thanks everyone, especially Joel @MBS for taking your time and clearly detailing my above questions.
@moon What is bothering you above? i did reread myself but sometimes that doesn’t help lol.
I have them. i will check later. very similar to superstars i think.
That was my feeling. @torqueboards we need your bolt diagram. @MBS just uped their game with theirs haha.
Mainly what tyres work on the hubs
Saw that rockstars work only for 8 inch but they also work for 7"
Also it said trampa superstars/hypas work on 6 inch
I do want to test something though, does trampa urban treads and TB 6incher work on all 3.75" hubs?
Comparability
I use a double thrust bearing
The axle for this hubs are 10.00 mm and most boards use 8 mm or 9.525 mm
The other option to use this hubs are with SurfRodz trucks that uses a 10 mm Axle.
@Sender uses it on his board
BTW compatible with TB 6inch wheel.
Weight, I’ll check and edit here tomorrow.
Out of stock
I’ve been using it for the spring batch
Is there some secret method I’m not aware of to dead easily put a belt+pulley+wheel on using shoulder bolts?
By dead simple I mean like, 5 seconds. That’s all it takes me for a fixed axle at this point.
Belt around motor pulley, put press fit pulley on axle, loop belt around, spin a few times, slap on wheel… Done.
Not so much for shoulder bolts. Tell me the secret, cause shoulder bolts are convenient as fuck aside from that.
I don’t know about belt drives but I do 35 seconds on a G-drive
My friend…
That is not a shoulder bolt
For sure it is not
probably it came out from a scanner and needs some detailing work
Nah it’s a normal drawing
I like those and they have a nice bolt pattern to attach a pulley. Some kind of 15T/100T should work just fine on those wheels.
This one has even a better bolt pattern and it’s cheap AF.
https://www.aliexpress.com/item/32950923656.html?spm=a2g0o.productlist.0.0.7157d8648uqAYl&algo_pvid=38375444-bad9-476c-8e5e-b8faeed31427&algo_expid=38375444-bad9-476c-8e5e-b8faeed31427-14&btsid=0b0a182b15826738821581176e6355&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
It’s basically the same with a shoulder bolt.
Belt on motor pulley.
Put shoulder bolt through wheel and pulley.
Install shoulder bolt with wheel on it. Give wheel a turn to line up pulley.
I’ve never had an issue doing it quickly.
You forgot the part where all of your spacers decide to fuck off and jump into the black hole of esk8
I don’t tend to need many. My wheel pulleys hold like 3 bearings each. Eats up most of the extra axles. I try to just run speed Rings or a single spacer and speed Rings at most.
I added Evolve bolt schema.
@torqueboards would be good to get yours, or some one who has them check? @DerelictRobot?
Cheers
