mbs fivestars are meant for 8 and 9 inch tires, they are hell to use with smaller tires.
Also, wrong tubes. Clever 6x2 are different tires. they’re berg-sized.
I’ve thrown 6"-10" tires on them with no issues ![]()
i must be cursed then
@Venom121212 is the fucking pneumatic whisperer at this point.
(Buttering him up because I might need some help soon.)
im sure he butters his hubs too. Sometimes I just end up pinching the tube so many times i pop a hole in it ![]()
Talcum/baby powder is your friend.
Literally what you told me last night ![]()
What is the tire seat width of trampa fivestars?
I’ve searched but can’t find the answer…
Do you mean MBS Fivestar or Trampa Superstar?
Trampa superstar
Are the bearings on the BN GT3 rims offset, or center set? They look offset, if so how much?
@frame do you have a measurements pic of the inner diameter of the cyclones rim?
@Boardnamics Could you post a diagram like the mbs ones at the top of the thread?
Info on the gt3s from the man himself:
The hubs have MBS bearing spacing, so 22.2mm apart from inside edge to inside edge.
They’re heavily offset; the overall width is 55.6mm, and the board closest bearing is sunk in only 3mm from the outside most edge. The rest of the hub carries over outwards.
Reposting for search and keeping
You get these yet? Curious about the fitment.
Hoping mine arrive next week.
I found these If some wants to roll the dice:
These look similar to clevers but round contact patch.
Also these Innovas? possibly
And Timo said these fit but I haven’t seen anyone confirm or try them.
