Pneumatic Wheel Compendium (Serious)
Are TB hubs bolt pattern the same as MBS or Trampa?
nope
I guess they don’t fit on the moon gear drive? :slight_smile:
They dont
Just discovered that you can find a lot of cool 10” ish tires by searching 260x85 tires
Okay so I went to harbor frieght and those tires labeled 10 in are actually 4.10-4(11in) tires not 3.00-4 (10in). Upon arrival at this conclusion I spotted these absolutely gorgeous coral colored bar tread 2.50-4 labeled 8 in. Which it is 9in but slimmer slightly than 2.80x2.50-4. Bought a set for 34 dollars.
They say max 30 but I’m running 45-50 currently
Also the in store label says two pr but the tire itself says four pr
Once again, that’s 34 dollars for 4 x tire, tube, hub. 2.50-4. Requires 4 in hub for 9 inchers.
Will report durability, so far they have changed my life hahahah, no loss of agility as far as I’m concerned, maybe it’s heavier but I train often and intense so I cant tell. I can traverse much rougher ground and the same terrain with more grip and speed. Also took it off a couple jumps at the skate park and the landings feel way smoother
If you have a go cart with the right adapter, or just use longer bolts and a 4 spoke sprocket. the hubs can be used there as well. I just already made spacers for fivestar pattern.
Not sure if it’s been discussed already here, any experience with these 6x1.5”? I may try to stretch them wide to 2”
Those look like motorcycle tires, definitely a good find. Please tell us how/if they work.
110$ after shipping for a set. Worth it?
They also sell 6’’ with the same hubs.
5 bolts in 71mm diameter circumference which might be compatible with gear drives that support Trampa pattern.
Also curious about them.
What are the largest wheels that would fit on berg hubs
7 inch?
110 / set seems a little steep but if they ride like heaven I’d pay that much.
this look good? it is probably a really soft rubber so non long lasting.
So I messaged the seller to to verify the hub diameter and he gave me the runaround, basically saying they fit whatever 6x1.25 will fit, should we assume the 3.75” hubs or the 2.8”?
I would say 2.8. AFAIK, no 6’’ tires fit 3.75’’ hubs…
??? Except the metro board, torque boards, sunmate, evolve tires? 6" is the most common 3.75in tire size.
Hello
Looking for my next wheel looking for some 100mm ish road wheels with flat tyres:) ? If someone could recommend me some thank you
Really thought 3.75 were mostly for 8’’ or more, sorry if I’m giving false information.
That means one can use a compatible MBS rockstar/fivestar or a Trampa superstar compatible hub with one of these tires you mentioned?
That would be very interesting for gear drive compatibility…
fixed this. @itsrow is actually correct, we just know 6’’ as bergs or ali tires but irl there are more 6’’ tires that fit 3.75 hubs than 6’’ tires that fit 2.8’’ hubs
the idea was that if you wanted small tires then you also want a small hub, but then people wanted more options with their setup so the 6’’ 3.65’’ era began
