Pneumatic Wheel Compendium (Serious)
you need very specific GD’s for 6’’ tires on a 3.75’’ hub to work. very hard combination to make work
100mm pneumatics don’t exist, the closest is either TB 110mm 72a or boundmotor 120mm rubber wheels
So the consensus is that most likely the tires I posted will fit on standard mbs hubs?
never seen an aliexpress 6’’ that fits on a 3.75, so the censensus is that they are probably for 2.8’’ like bergs. i would ask the vendor for a pic of the inner diameter measurement, that would sort it out.
I would say 105mm airless rubber tires and 105mm Cloud wheels are actually closer to 100mm pneumatics.
6 inches
Flipsky 6 and 7" also might fit, not sure.
Thinking about the moon one. AFAIK next batch will only support trampa and MBS patterns, dropping support for the bergs.
moon drives can do 6’’, look at @Venom121212 Circuit board build, but clearance isn’t huge.
Only if you forward mount the motors :muscle:
Bergs will not be supported in the future:
since then I have not been really selling many Bergmeister setups, future batches will ditch all support for Bergmeisters
that’s just the bolt pattern of the bergs though, it won’t stop you slapping some evolve 6’’ tires on your mbs wheels
Perfect, that was my original question :joy:
lol sorry
No problem, I do mostly kicktails :blush:
what 3inch wide hubs are there?
i know metroboard widened but anything else?
also can i just widen trampa hubs the same way you widen metroboard?
Someone made a spacer for Rockstar iis, I believe it was @Pedrodemio
Edit: It was @ZachTetra and @mishrasubhransu
what material can you use to make it?
or best cnc’ed?
also for tires what do you use?
The spacer is for superstars.
Idek I don’t have a printer lol
