Thank you!
Hey I would not recommend this configuration. I tried this and I’m not getting enough power on the high beam on one light
when I use high plus low beam
Dang! That’s really unfortunate. It seems like you might have got a dud. I test these all before I ship them out so I’m surprised to see that happen. We can get a replacement started for the one that won’t switch. You were able to check the wiring for both right? Like if you plug in the wires for the other one, it shows the same behavior?
I did. I ended up using the dual spdt switch configuration because I thought that using a single dpdt switch to wire for both high and low was not giving enough power to one light.
But I have the same issue with a dual switch setup as well.
I also sent you a dm with the details.
And I just switched the cables. Same behavior. It that same light acting up.
Yeah probably a dud. You can ride with that one until you receive a replacement and then ship back the broken one - I’ll respond to your DM tomorrow.
Awesome! Thanks !
