Ohhh maybe.
I only built coils below .1 Ohm
I regret using it. Waayyyy more work now than having just been safe. And there’s no no reason to rims a multi hundred dollar pack because of a $5 part. Hindsight my man.
Ohhh maybe.
I can’t imagine I did any substantial damage I also can’t imagine using a cycled cell in a esk8 pack like wtf you trying to get a campfire started?
/s
Haha no I was just the biggest cloud chaser. Had a Kennedy Rebuildable and just blew the fattest smoke.
I was sure as shit that guy.
As for using it in my pack. I didn’t actually use that cell all that much. But it was enough to ruin the group.
What app is that?
The redundantly named “accelerometer meter”
Missed opportunity.
They should have called it “Acceleration Measuring Accelerometer Meter.”
Relevant Post:
You got your battery fixed now, right? I vaguely remember your post about one cell came from a vape?
If you need cells, I got some.
Its fixed yeah. Had nothijng to do with the vape cell at the end of the day. I checked tge individual cell’ capacities. all fine so Mustve been a bad weld
Do you think 2.5V or so sa is normal?
That’s pretty low. 2.7 would be “my” nominal normal
no I mean sag under load.
When I pull ~45A, my battery drops by about 2.5V
as data points i submit the time stamp around t =20:18
38V @ 2A,
and then
35V at 47 A
That’s a lot of sag. Mike had almost the same issue. We honestly thought it was his Batts but was “fixed” w better gearing.
the gearing is tall as hell.
Was this on Berg’s or thane’s?
bergs!
like butter now dude
how’d you forget? you set them up haha
LOL. Not sure if the issue was before the switch. Haha
we’ll see.
I havent measured teh bad group since the fix. I charged them up to all within 100mv and then went for a ride.
Now I wanna measure the groups again, then charge it up and see whats what
Holler if you need help. I’ve been meaning to go to Jason’s and get the guest board so I can finish it. I’ll hit him up.
