Hello everyone.
I’ve been thinking for a long time, how cool it would be, If there was a thread that contains time-confirmed configurations for everyone who wants to try to build a new board.
Let me explain what i mean. We all know that board starts with the battery. Lets say some dude (like me 3 years ago) decided to use 6s LiPos. Well, he calculated erpm, and selected 400kv motor, because he did not even know, that there will be no usable torque. So he moved to 270kv. It works flawlessly. Now he purchased the gears with ratio 2:1. Wow, so much speed - he thought. And at the first ride he smells the burnt winding coating. Ooops. So he moved to 1:3 ratio. And so on and on…
So this is the topic for you to share your configurations that worked and work up to date flawlessly. Optionally, you can add pros, cons and summary
So, let me start:
6s - single 5065 270kv - (12:36 ratio) - 83 mm thane
Pros: cheap, all components run at small loads (no heat)
Cons: brakes succcc, belt slips.
Summary: cheap setup, optimal for kids or really lightweight guys. Otherwise - see cons.
