That actually looks good enough for the type of ledges around where I live. Thanks!
Just don’t wear baggy trousers, and keep your shoes tied!. ![]()
Yeah I have like 1mm of leeway for belt tensioning if I do this. I think I’ll just decommission this build for a month and get your drivetrain. (So now I need the whole thing, not just a front truck
But then I had an idea.
With enough ground clearance you can mount RKP trucks the other way round to make reverse mounting easier. And look at that wheel-base now! ![]()
I think I will order some belts and give this setup a try. For science! ![]()
You know what’s crazy? My gear drive ratio was 14:36, so to get an equivalent top speed with a 48T pulley I need a 18.6T motor pulley
So if I go 18T my top speed will take a small hit. And I’m already at 190kv motors. Maybe I’ll have to switch to high voltage in the future ![]()
(Or just go 16:40 for some extra ground clearance.)
Actually, I guess my current motors were actually 170kv because otherwise my efficiency has to be really shit to only get 53km/h top speed
So as long as I swap my motors to true 190kv ones I should be fast enough with 18:48
(16:44 also very similar)
Are these cells usable in a rebuild using nickel strips after removing them from the modules?
If you want to confirm your motor KV for troubleshooting - this method is fast and easy
In my opinion as long as the builder is absolutely sure they are otherwise in good condition, yes. The arc marks can be removed, if not deep, with a Scotch Brite Heavy Duty scrubber pad.
Thx much.
So this board is going to receive a belt-drive over the winter. I think I might swap from Surf Rodz to Luna trucks as well for some extra width + precision bushing seats. (Or Savage trucks, but I’m currently using them on another build) Question is do I run small motors, or extend the wheelbase so that I can have the motors clear the end of the deck and put some big Radium Reacher motors on.
I know I’ve always argued for increasing gear ratio in the past for optimal motor efficiency, but… If I were to put Radium motors on this build, which would make my Stormcore ESC the bottleneck rather than the motors, how dumb of an idea would it be to go with a very low gear ratio (say 36T : 18T) and a low-kv motor to make up for the torque?
Pros:
- Better belt clearance
- Better free-roll
- Better tooth engagement
- Quieter board because the motor does not spin as loud
Cons:
- More stress on belts when accelerating and braking
Thoughts? Alternatively I could just get a MakerX D60 and get more out of the motors that way…
I’ve ran 125kv motors on 2.6 and 150mm tires and it felt really good. There was plenty of torque and good speed. I also didn’t have to run a lot of motor amps 70 was plenty for low end torque
