oh yeah that works, beats the $9 shipping fee at aluminum spacer dot com. thanks!
No problem. I didnât realize that redz shipped bearing without spacers. So ended up having to look for those
36/16 gearing
320 belts currently but I need to motor to sit as far back as possible as show in the photo, what belt length would be a good estimate to get this fitment
Most use regular 608-2RS skate bearings but some use 6900 (Evolve) or 628 (@dickyho) bearings. The 628 are better bearings because the balls are bigger.
Right here bruh
https://www.amazon.com/Nimbus-Spacers-Washers-Skateboards-Longboards/dp/B081KSP3WD/ref=sr_1_22?th=1
Didnt realize that was your post. I saw this earlier and used it to check if I had everything with my build at DIYboards but now I guess Iâm scratching that and starting over haha. Its a good guide. Thanks
https://www.bbman.com/belt-length-calculator/
Go here, and enter all your pertinent details: Belt pitch, pulley diameters, distance between pulleys.
so I need 12mm speed rings
10mm speed rings and spacers
know a qwik source?
I thinksss I got some 12mm speedeezzz from
Here. https://www.havocspeed.com/product/fragola-999212-1-12mm-aluminum-crush-washer/
Got me 10mm speedeezzz from
Here https://www.ledakartn.com/index.php?main_page=product_info&products_id=586155
And spacers I think I had got from trampa at least 10mm onezzz
I should probs findz a place that seellz all in 1
Ainât nobody gots time to go to so many different sitesssâŚ
Oooofffff⌠wellls they gots some of Deeez. https://trampaboards.com/shim-spacer--bridges-the-tiny-gaps-between-bearings-on-10mm-axles--10-x-16-x-05mm--p-24602.html
Ohhh shyyttt they gotz 12milliii
Too.
Use a piece of rope and wrap it around
Hereâs moar spacerz for yaaaa one of dem gotta work
Is it safe to run VESC 4.12 in a 4s battery configuration?
Iâve seen the thread on how to make a loop key so I understand that part but how do you do it with a unity if you remove the switch does it instantly power on when plugged into a battery and is it fine to have xt60 on the battery and unity and then xt90 for the loop key
It will most likely work but the power output will be limited to ~750W (based on 50A continuous for the 4.12 hw).
If you have the possibility go for a minimum of 6S or 8S, this will give you the same amount of power with less strain (lower currents) on the VESC.
Thanks. Well I think current wonât be an issue since this is for my 6 years old kid. He not more than 15kg I think. I would like to go as light as possible, I would make acceleration curve really slow so he wonât get hurtâŚ
Also range is not an issue, everything more than 5km is more than enough.
