NEVAR!!!
I knew that would trigger people.
I feel bad for it you know?
Never do that again.
I’ll tell my kids when I’m older…
HFI:
Sounds like the best thing to do
Looks for YT Tutorial
Sees 15min clips
clicks although scared
sees this:
jumps from rooftop
This is what I remember of HFI.
This weird points / graph thing.
Do you still have to do this manually?
Or is there a wizard / something similar?
Can you use it on 4.12 VESCs?
you know you can edit your posts… and add quotes and shit to not clutter up the thread…
…looks in mirror
never mind you’re k00L…
Can someone make an hfi setup thread
Not a video rather just a stage by stage thread
Please
@b264 ?
@Pimousse make a really good one
+1
And compatibility stuff…
Why it’s better than sensored FOC etc
Je ne parle pas le baguette mon frere
It’s better then sensored foc because often the sensors break and also sensors take up more space in the can which could be used for a bugger motor
What glue is recommended to glue the screw counterparts (how do you call these?) inside the wooden holes you drill in your deck? 2 compound adhesive / gorilla glue / epoxy? Or can i use loctite?
I know Brian is going to say JBweld but regular 2 part epoxy works fine.
Maybe you can add subtitles!
You should test if the lines keep close to eachother when slowly turning the wheel.
But yeah, in the tutorial Benjamin said you want the blue lign to match the red like and make the red dots as close to a line as possible.
This looks very good from my perspective
Yeah thanks with all the tests I couldn’t get a wave only a line
Will see if it works
As said above: you have to slowly turn your wheel in order to see the phase line something bla
As long as the xt90s connection is the part that physically plugs and unplugs yes.
