For XT90’s you could use a panel mount as long as you have a flat side on your enclose. Look on thingiverse and search Xt90 panel mount. There are loads that you can 3D print for free or can find these on ebay.
Edit - For phase wires I’m using these Cable glands to make sure the enclose looks clean and is waterproof and am routing the wires with these cable tidy clamps.
A split angle setup is nice if you have the option. Higher degree up front, lower in the back for carving and stability at speed. I run 50/35° front/rear.
if i’m shopping or currently not riding, i grab it by the truck and drag it behind me. Due to the 50° truck the deck is angled different and scrapes easier. Thats all ^^
I see, haha. Didn’t think that much out of the box
As far is I understood, the bigger the angle, the more it will carve, and for better speed stability I should choose smaller angles :)?
Twenty seconds via Google xD
I don’t think they try to troll you and make it different ports on each board
Just type every information about your part you have on Google and voila
Cheers!
Btw:
The pin names tell you to the remote receiver gives PWM signal to your controller with a certain duty cycle which equals motor power %
Normally the remote plug is 3 pin as in the picture, I guess the extra two pins (being RX and TX) are for Bluetooth stuff
“A high angle will give you more turn for your lean, but with a lower angle truck you don’t get as much turn from the same power you put into your lean, increasing stability.”
Make sure your motor shaft diameter matches the pulley inner diameter too (10mm bore) . You could just message the seller and ask to include grub screws. If not, they’re dirt cheap at a hardware store.
