How 0.o?
There is plastic preventing the bearings to come to close to eachother. Are you dead sure?
These are 97mm abec clones
yes, i have skateboarded for a while
I know you use these for standard size wheels, but the 97mm ones have spacers out of plastic in their designâŚ
So Iâm confused how they should fit there
put one bearing in then the spacer and then the other bearing
I feel dumb not knowing how to put this spacer in, since the bearings are separated by pitch of the plasticâŚ
How do I fit the spacer in there?
It would just fly around if I put it in there
BearingâspacerâbearingâŚturn board on side, put wheel on and spin it, will settle down onto axle.
Thatâs what I learned too, but I struggle with how to do that bearing-speacer-bearing.
How do you get bearings out? Raw power with a screwdriver? Maybe I can post some pictures so that you can help me? ^^
well first of course you have to take one bearing out, then just put the spacer in the wheel so the hole is in the same direction as the bearing hole. Then you put the other bearing in
it moves around, thatâs normal xd
when putting the wheel on your axle youâll have to align it with the bearing holes
How am I supposed to align it with the bearing holes :((((((
Stick small Allen key through bearings + spacer, slide wheel into axle while removing the Allen key at the same time. Boom, you got yourself a mounted wheel.
also this â
i just put the wheel on the axle and spun it until it dropped down. But since i exclusively use zealous bearings I donât need to anymore
thatâs a different type of wheel, on normal wheels you canât do that
The wheel is different obviously. But the way to install it is the same and thats what matters.
What did I do wrong?
ow never mind, i thought he put that whole stack in the wheel in 1 push, xd i didnât watch the whole vid
perfect, thatâs how itâs supposed to be
As I assumed, the spacer is now freely doing its thing in there
Thats why I thought I donât need it, since it doesnât fit in any hole or something
