Hi Remo. I bumped your account so you can post and message right away.
Welcome!
To start a thread, click the esk8.news logo and select the ânew topicâ button top right:
Welcome!
You are getting too fast, hombre. Thanks.
as i tell my wife - everything is a race and iâm going to win no matter what happens
So thatâs why you always come first
I am clapping right now. Donât focus on the fact that Iâm not wearing pants.
Sure no problem
Then consider adopting this strategy
If youâre going to use sensors, then yes hybrid mode is what we use.
However, I suggest physically cutting off the sensor wires entirely and running unsensored.
Either:
Ackmaniac 3.103 âBLDCâ âunsensoredâ mode (rock solid, no bugs)
or take your chances and run a new @Trampa version like 2.03 + 4.2 and run âFOCâ in âHFIâ sensor mode
But either way with no physical sensors wired to the ESC from the motor.
I wouldnât run Trampa firmware unless you need HFI
. Â And I would recommend using HFI.
edit: Iâve been testing 2.03 + 4.2 for a while now and the only bug Iâve found is related to reverse on unsensored BLDC mode, so youâre unlikely to find it following my advice. Donât roll down a hill âswitchâ (backwards) on 4.2 in BLDC with a max (min) reverse speed set, or youâre royally fucked
Will they remove STDs from the
you know what, nevermind
HFI?
I use ackmaniac (donât know what version, the one recommended for Mac) and plan on riding with foc, with hall sensors hybrid ⌠why is that wrong?
If you run sensored FOC, you donât need to worry about HFI.
I have my metr connected to UART (master) and my DavegaX to my AURT (slave)
Davega is all good
Metr doesnât show live data
LEDS are both blinking and app says connected
Do I need to change something in vesctool?
I already send message to Dario, but I thought maybe someone that is now online knows this??!!
Itâs not wrong. Some folks do not care to rely on sensors in the motors.
HFI = High Frequency Injection: this method is able to detect the rotor position without sensors while the motor is not moving
What vesc are you running again?
edit : maytech superfoc 6.8
Superfoc
I think I have wrong baughtrate on master
But should be auto detect
You might need to swap RX and TXâŚBUT iâm not sure if thats still needed on the metr pro. @rpasichnyk
yeah metr pro auto detects. Check if its 9600 or 115200
also, if you go into the expert tab, does it say : FW 0.0 not supported?
Do you measure the entire length of a bolt or just the length of the threading?
Itâs either ~18mm or ~23mm
Hardware in question:
E nevermind xd Iâm dumb
just the thread length
