I got a VX2 that was cutting out several times an hour and also doing the uncommanded acceleration thing.
PropulsionBoards sent me a replacement and those two problems went away.
I’m in line for a freesk8 remote which should be coming out soon - way way more expensive but I’m holding out hope that it will solve my remote problems forever.
I didn’t really suggest it I suggested he check if his VX2 (if he has one) was busted (as mine was) and replace it (as I did) I then I said (as an interesting side point) “I’m in line for a freesk8 remote which should be coming out soon - way way more expensive but I’m holding out hope that it will solve my remote problems forever.” which is exactly what you are saying here.
I had this EXACT same problem. The white (signal) wire ended up being cut, between the receiver and the ESC. Check that specific wire for loose connections. The stray capacitance there still allowed it to work somewhat, but with these exact weirdisms you’ve described.
The VX2 on my Flux went out for a moment today with the characteristic double vibration warning. Lost brakes and almost rolled into a busy street. Veered to the side to do a turn and grabbed a traffic light to stop. It’s not the most reliable as remotes go, my other Hobbywing China-motes have held up flawlessly so far.
Does anyone have a recommendation for a 90V to 12V DC-DC buck converter? Looking for something that can do at least 10A. Ive been looking at options on Amazon, but if anyone has something they have tried and would recommend, I’m all ears
10S x 4.2V/cell = 42V (fully charged)
10S x 3.6V (or 3.7V) = 36V (37V) “nominal” voltage that merely identifies what battery chemistry is being used. Ignore this voltage.
For glass frit I got 96-01 coarse frit, but what do I know it’s only my first time… I think the idea is Frits large enough to poke out of epoxy like glaciers where most is submerged.
has anyone been able to get boardnamics AT gear drive to work with 9in mbs T2 tires?
the 8in tire works . Am I missing something or it just impossible to have 9in tires on these drives?
f
If I turn my remote on then my esc (ubox) then my remote will work. If I leave my remote off then turn on my esc, only then does my davega work. What do i do? I guess its a setting for the uni1 remote like ppm+uart or something?
