Don’t know yet. I’ll get rid of em when I get my tb110s.
For decks that have 2 set of truck mounting holes, what the difference in a shorter or longer wheel base? How will the ride change if any?
Assuming your trucks remain the same, with a shorter wheel-base you will get a smaller turning circle/radius, and with a longer wheel-base you will get a larger turning circle/radius.
So if you want to get some more stability by making your existing trucks turn less, you can use the longer wheel-base option. On electric skateboards with big wheels, often you will be forced to use the longer wheel-base option just to avoid wheel-bite
Or vice-versa, if you think your board is already really stable and you want slightly sharper turns, use the more narrow wheel-base option. Might also make your board more compact / easier to carry.
Thanks for that, good explanation!!
Is there any vendor besides infintyXs and davega baseplate who makes “x thing” that fit both old and new school? It doesn’t have to be x shape, any shape would do. Im just looking for options
Set control mode to off or none
NOT app to use, this will kill bluetooth
Alternatively the easiest way is probably set the motor max current to 0.
yea i saw those, was hoping to find something that works for both old and new school at the same time
Hmm not sure then, I don’t think I’ve seen any that accommodate both, sorry
its alright man, guess i will go with davega baseplate then, those are cheap af to get a stack
Why can’t I get the 3dservisas calculator to work?
Who has access to fixing it?
Can we pay them?
I will put money towards fixing it.
My bad, they did fix it. Seems to work okay for me now.
why not this?
Oh sweet, tyvm!
ublock origin started blocking one of the scripts that’s needed for it to work some time ago. So disabling your adblock might help.
That calculator has a bunch of things missing; most notable for me is speed at full battery, average battery, and empty battery.
Haven’t put them on yet but I think they are new school @Savage1 can you confirmed I’m out today can’t measure
@Nacho So the black ones you have from us are OLD school. They are 1.625” x 2.5”.
(New school is 1.625” x 2.125”)
It looks like the used ones you have, based on the screw indentations, where old school as well.
