Guess I skipped his reply, woops lol
Hi Guys, does anyone know if a benchtop power supply could be used to charge a board? I’m not sure how it’ll compare to a charger where the BMS reduces the current to balance.
Yep, see this charger I made:
Range is a function of total pack energy, not voltage.
yes, but when i just add 2 parallel groups the total Wh will be more so i’ll get some more range, right?
Perfect, thanks!
Yea, around 20% more range.
Am i stupid? Did i miss something?
@Anubis (your bearings) and anyone else with bergmeister hubs, what’s going on? Do these hubs not use 10mm spacers between bearings?
Common issue with bergs, mine did the same.
Had to file the spacers a bit.
These are too short actually… adding a 1mm washer in the middle makes either bearing stick out by a tiiiny fraction so i assume it needs a 0.8mm washer to sit perfectly
So if you tighten everything, the wheel doesn’t spin freely?
If i tighten it as far as it’ll go i completely mess up my bearings
put a washer in and tighten it just very slightly more than usual? it shouldn’t affect much
Weird, I have zealous bearings in mine and didn’t find this issue
You would in theory but adding parallel groups like that isn’t a good thing to do.
You really want all the cells to be the same age and condition. (Technically you want similar internal resistances)
Maybe if the battery was only cycled a couple times and not run very low it might be fine. There are a lot of variables but in general, adding P-packs bad.
Cant pair my android with Unity over Bluetooth - getting ‘Pairing Rejected by Unity BLE 1.1’ message
… any ideas? (trying to set up mobile VESC tool)
Don’t pair it from the Android OS, open the ESC Tool first then pair from there.
I tried using the VESC app, but it’s not connecting - at least theres no obious way of connecting over bluetooth - tried following this - https://www.youtube.com/watch?v=P8e3GYOL4d4
Also don’t select the option that says “pair” unless you write down your ESC UUID. That’s essentially locking you (and anyone else) out of it from any other device, like a password.
