I have a drop through hummie too with a similar bushing setup, after getting wobbles with the default venom cones and stuff I took a spill
Now when I go over things that cause the deck to shake I keep thinking its speed wobbles but I think I’m making it up so I usually check and it’s fine. Still working up to going fast again though
When I start my mtb the motors kind of lock up and I have to help it by jumping and swinging forward (they are sk3 192kv motors), also like they are a little out of date, when they are in the air they both rotate the same but when I am on top they do not rotate same. I weight 68 kg
that’s normal?
VX1, flipsky dual 6.6, Tb6355s
Setup, detection etc all went great whether plugged in individually or accessing the other side via can
I can slowly move and invert motor direction in the vesc settings
Applied, unplug, reboot. Only master side wheel has power. Slave is doing nothing
App settings general
PPM and UART
Permanent UART true
CAN mode VESC
UAVCAN ESC index 0
Have had this before and don’t remember what I was overlooking. There is no physical can cable for this esc
PPM - multiple VESCs over CAN is set to true
If i go into the APP setup wizard, it says one of the vescs has old firmware when I try to scan the can bus (even though the can vesc is already found and modifiable and moveable via can before starting)
EDIT – Got it… Can status message mode. Set it to 1_2_3
I use basically 2 sets of bushings from evolve’s store, they’re made for the dkp trucks but handle just fine.
Rear is yellow deck side (92), purple street side (90)
Front is full purple
Not a single speed wobble ever, and my board maxes out at over 50km/hr every morning.
I do believe that top mount was a bit… sketcy, but still never threw me off
The only thing i don’t like, if i find a road with waves in it in just the right places to resonate with my deck’s flex, it will swing me up and down until i almost fly off it and need to slow down/swerve
I think higher weight will make this flexy “feature” even worse
Yes I feel this too, weird resonance with the decks minimal flex. Throws off my mental game sometimes. Like I know it ain’t speed wobbles but it kind of feels like it.
I have a 12s7p in mine of 18650’s
all 87a Riptide bushings, Rear RS is canon, rear BS is chubby barrel, front RS is canon, front BS is fatcone
Does anyone know what on earth can cause this crackling sound? I’ve tightened and loosened the axle nuts to no avail, and loosened the belt. I doubt it’s a motor sound, and I’ve never had this crackling sound before
Hope this helps: VID_20200917_180553|video
This is how tight they are after I loosened them. Did the test where you hold the motor and wheel and twist with no slippage?
I fixed it, at least for now. I think it was a combination of my axle nuts being too tight and beings not being seated properly; after I gave the wheels a good push to seat the bearings along with tightening down the nuts a bunch (then backing them off) the sound disappeared
