Not trying to call out his work, just trying to understand what’s going on. I can see that it’s doubled up, but is the length of the strips what makes this work? Can you estimate the carrying capacity?
40V 25A AC -> DC should do it when doing high power charging though need to make sure all the connectors and wires can carry the current without roasting. Recently saw article about my old dorm for the year I went to purdue had a small dorm fire from an esk8. Pretty sure the whole place was cinder blocks and tile so pretty hard to burn down but apparently they roasted the room and bad news for esk8. Was 1am so guessing was charging, be careful if trying to “fast charge” things.
It’s because the current is flowing across the nickel, not along it. Those look like p42a 21700 cells, stacked 7 wide. That means that nickel strip is a little less than 147mm long, let’s say 135. 135mm x 0.2mm = 27mm2.
Remember my estimate of 10awg copper equivalent was 24mm2 of nickel.
Indeed! Especially now that our elementary school math teacher’s worst nightmare has come true and we DO in fact always have a calculator in our pockets!
I run two 6s 20 ah lipos in series. I currently use a 10a 6s charger w duel output but I think it only does 5a under duel load. If I drain the batteries completely it takes 4 2hr cycles to bring them back to full
