So would I read voltage on each separate wire?
Just went to homedepot and found cable clamps for $1.80! I’m happy now
I’ll alert the appropriate media…
Im looking to buy a gear puller, but am slightly confused.
Does the length of the puller matter? I see sizes ranging from 3inches to 6inches
Its nearly at the end of the motor shaft so I figure 3" should do… just wanting to make sure before I order and facepalm when it arrives.
That looks like the chinesium excellence Mike Beard likes to push maybe hit him up.
shame…shame…shame… on you… shame…
and shame shall be your name
Does the Lacroix Stormcore use a 7-pin Vesc-4 UART connector, or 8-pin Vesc-6 connector?
Thanks, I will buy it. Also I can you both versions of that remote you send?
Not fully getting this. I have the early remote you showed, and it’s a huge piece of crap. I also have the remote I linked you to, which is actually pretty nice.
Come on You can’t be the only one who has a issue with MB
no battery cut-off will be all fukked up
Ok, thanks
No idea. They could be switched to 7s on the early ones, though.
Does using outdated VESC gear ratios do anything bad other than showing wrong telemetry?
For example limit your speed somehow etc?
Has the erpm limit effect on it?
If you do profiles to limit speed it’ll do it wrong. Otherwise no biggie. My bluetooth side has like 20km registered and remote side about 13 right now
I more knowlegeable in concrete beams than in metal plates, but i don’t like the look of it.
Were your screws loose or something ?
