Recommended source for a nice steel 12 or 13 tooth motor pulley for a 15mm belt? TB has the nice ones with the big set screws but 20mm wide and $15 a pop kinda hurts
I think you have it configured for 10s or something
They are not a bad board but battery is a joke…
Yes Just checked it…was not set up as 12cells. Thanks for the Tipp
Also has anyone run 72:13 on BN idler mounts? The math says 420mm belts not counting the idler but I have no idea how much it’ll add to the length…430mm maybe?
Meh. Deck is a piece of shit, dkps on that short wheelbase are gross, battery is shit and electronics are limited at best. Personally I don’t see the attraction.
Doing a deck swap for a mate I have almost talked him into a full upgrade not much of its going to original maybe just the bearings.
Who the f ever said it’s cheaper? Maybe @Halbj613
Build kit boards
Why do I keep forgetting about BKB when it comes to cheap prebuilts? Dammit @glyphiks you should’ve told me!
Ownboard bang for buck, better build than exway yeyang ESC is better than hobbywing. Easier to upgrade with diy than a lot of prebuilds.
I know, right?! I just forgot. Plus, the new Duo is here in two weeks!
I’ve been lurking around and watching commercial boards as well and i am thinking that a DIY might be a better choice for what I am looking.
@BuildKitBoards is your huckleberry.
You know you have an issue.i bought a new vw today and paid an extra $8k to get an extra 8 inches trunk space to fit my esk8s in. Is there an AA for esk8.
thanks for the help il look into these settings now.
Check out BKB as already mentioned, but also Nexusboards UK. Nexus is offering kits now or soon iirc.
You are already here
Gents, hows the gear backlash looking here? @Andy87 @taz @rich @moon
Video
https://streamable.com/rmbtj9
https://streamable.com/2u9mkj
Photos
Who did or who sells enclosure Landyachtz top speed?
Maybe fit from another board.
Sounds like the Carbon GTO
I did reuse the four heatsink bolts ![]()
If you hit the settings gear, you can change it to percentage. Did you set your battery type up correctly? It thinking 48.1 V is full isn’t right obviously.
@mutantbass that looks a smidge too close imo.
