Ok, thank you for your advice, I’ll definitely give it a shot. I’m still a little confused how the motor can draw 85 amps when the battery is set to 50 amps.
Edit: I tried 80 amps on a flipsky a few months back, and the motors did not get too hot, but my battery max was also up there.
Oh yeah that’s fair. Basically the ESC switches power on and off to the motors in very fast cycles. At 20% speed, it pushes 85A into the motor for ~20% of each cycle. This “on time per cycle” is the duty cycle. [1] [2]
The ESC has large capacitors that average out the current draw across cycles, so instead of seeing very quick spikes of 85 the battery sees an average of (85)X(0.2)=17A.
Biiiig simplification there, but there’s a thread on it with a few explanations
[1] The reason the motor isn't jerky when you're turning the power on and off all the time is:
It’s got a lot of mass and rotational energy, so it’s just really hard to change its speed with a pulse that’s 0.00001s long
It is an inductor, which stores and releases energy in its magnetic field. If you don’t like electronics, this functions similarly to intertia in a spinning mass.
[2] I’m using 85A assuming full throttle. The same maths applies at any other value: ie half throttle at 60% speed would roughly look like (42.5A)X(0.6)=25.5A
It could be done with the right tools and skill but that design is far from optimal.
A better approach would be to weld pieces of round tube on the square profile that the bolts would then pass through.
It’s about braking behavior. I came back from buying groceries and as always got annoyed by how quickly i saturate my battery regen amps (7A per side) Why only 14 amps? Cause I’m only using a 2p p42A pack and 8A per cell is the safe limit i believe.
But what i noticed is that i immediately hit the max 14A, the motor amps weren’t that high this having weak brakes. After the strong brakes kicked in the battery amps went down and the motor brake current “increased”.
The simplest answer is that higher the battery amp regen number, the better your high speed braking.
Braking power is the reverse of this chart, specifically the part in the yellow box for your situation. If battery amps are constant, phase amps are more powerful at lower speeds.
Another way to think about is to ignore motor amps and remember that volts * battery amps = total power.
So 14A x 37v = 518w. You are limited to 500 watts of braking power with those settings. That might be fine when you are doing 5mph, but will be inadequate when doing 20 mph. Your mass carries a lot more energy moving at 20mph, and you need more energy to slow that mass down (I’m not calling you fat, I swear).
The only way to improve high speed braking is to increase the battery regen number. It’s been said before on the forums that some people are OK with the potential of reduced cell life by going over the datasheets charge rate as a trade off for strong high speed braking. Since that charge level is so brief, and you only hit those numbers under full braking at high speeds, the impact to cycle life may not be that bad.
Another option would be to add a braking resistor that absorbs the excess power so you could safely raise battery regen amps… but I’m not sure if there is a good off the shelf option for that.
Is there a way to use active/smart braking over UART? I can’t find any options to set it outside of PPM control. Currently using Flipsky VX2 with VESC 4 fw version 3.4, VESC tool 0.95
On two VESCs I have, one is FSESC 4.2 on FW version 3.103 using Ackmaniac tool, another is a Maytech VESC 4 on FW version 3.40 using VESC tool 0.95. I’ve been using a Flipsky VX2 remote. The remote works and I can set the motor parameters just fine, but I have no controller options under UART:
UART has no customizability in terms of curves or modes on the vesc tool. It’s all done on the remote itself. If it doesn’t have options, then you’re out of luck.
Everything works as intended, it needs more energy to get your fat fuck to a stop so increase the amps for stronger and especially safer breaks which as a trade-off will hurt your cells life.
So, I just got some brand new MBS fivestar hubs. Was very excited to be able to run a variety of tire sizes. However, the bearing seats are sloppy, even with ABEC 7 bearings. There is wheel play that isn’t acceptable to me . I have spacers on all wheels.
I am looking for a long-term solution to this. Upon searching the forum, the only suggestion I have really found is kapton tape. Loctite 641 could be a potential solution, but who knows whether I will get a decent bond between metal and plastic. Teflon tape could also work, but not sure how long that would last.
