It has been done in the past on SK3 motors. The only difficulty really is securing the wires for the hall sensor effectively, Imo
You basically just have to epoxy a hall sensor at the three locations 120 degrees apart, then run all the wires out. How much space is inside the motor makes a difference too, SK3’s happened to have tons of room. I haven’t done this myself but it seems easy enough
Want to set up my vesc tonight/tomorrow for the first time! Are there any (important) things I need to keep in mind about for example the settings? Or a link to good information? I have seen some videos on YT already
I did it once
Bigger pain then I expected as I had to deal with small wires which got destroyed quite easily
I’m def not the best man for precision jobs though
Def possible but requires patience and being careful
Unities are 4.xx, not sure how much the modifications and development Jeff did impacted that specifically, but FOC 12S unities are pretty damn common.
Veeery second hand info, but I’m sure I’ve seen people at 12S FOC be told to either go 12S BLDC and hold their breath, or go 10S FOC recommended. Absolutely no testing of this advice, but since you’re asking for anything at all
Edit: actually pretend I PM’d you this, I’m gonna delete it in an hour or so so it doesn’t get left in the permanent record for a noob to find
I used to run a TB 4.12 back in the day on a 12s 190kv build. It worked fine on 12s BLDC, but I put a hole in the DRV chip on 12s FOC just testing on the bench. That was ~2017/2018 and I’m not clear if newer firmware fixes that issue or not. The recommendation (before the v6 existed) was to only run 10s FOC or 12s BLDC on any v4
