I’m trying to forward mount motors with a short EBS motor mount for looks/stealth, and to keep the length of the board down. In the current config I get motor bite so that’s not going to work, but I’m anxious about angling the mounts parallel/close to parallel with the ground. At the moment I have about 40mm of clearance so realistically it isn’t actually that bad. Am I basically left with either lowering the clearance or adding a riser?
40mm is fine for a street board, could take about 10mm off and be okay IMHO.
For offroad, ignore all of this.
Cheers, because the mount doesn’t have 360° range and the next step up is wayy too low I ended up changing base plate from 44 to 50. I now have 30mm clearance and far from biting. Might actually nudge it back up a bit to get 35mm if I find it too close, but looks like the new baseplate worked a treat
Yeah Thanks! I did this phase wire test after buying (tried it also out today again). It feels okey for me, only thing is when I’m spinning my motor without connecting phase wires to each other it doesn’t feel as smooth as when I’m spinning my wheel for example. I feels a little bit choppy (but less choppy then when I’m connecting 2 phase wires). I only feel this when I’m spinning slowly. Unfortunately I can’t do the test with a drill, because I cant get off the motor mount and that causes that my motor axle is too small to put on the drill.
Yesterday I sent a message to Banggood as @itsrow suggested, but they won’t help me out because of exceeded waranty time.
Weird enough I had the feeling yesterday the resistance was higher when I tightened my bolts. Because today I don’t feel that much resistance ( There is always a bit resistance i guess?)
Do you think i could try it out on my esc or is it a bad idea?
motor bolts? how long is it? maybe it is touching the winding inside
Wouldn’t it be ironic to lose access to the lounge because you were only active in the lounge
could be worse if no one like any of ur post / reply ![]()
Ah measured it its about 1 cm. So could it be it’s touching the windings?
its possible, mine are always 8mm in length only
I got included when I bought my motor mount. The bolt it self says 8.8 DL
if u have a multimeter, do a continuity test and see if any is too long
Ah interesting. I will try out, thanks!
What should I dress my board as for ren fest??!
Which weeb shit is that?
JP: 名探偵コナン
EN: Case Closed (aka Detective Conan)
Hes never gonna solve it. The case will never actually close.
Edit to add: blackjack and lupin are way better imo. Not that Conan’s bad.
the fact that everywhere he goes has shit happen, there will just be endless case for him to solve
Thousand episodes later… “I was an adult, then I got turned into a kid. Then an adult. Then a kid again. I think I wanna try being a cat.”
u would think that the first case he tries to solve is how to reverse that drug which made him small, but no, he goes about his day until other shit happens, then 6 thousand years later, still smol
