The older makerx bluetooth modules have pretty weak signals, which is why they just made a better one. Could that have anything to do with it?
@jjhoyt or anyone else who can help
i have a hoyt puck
connects fine and did pairing fine
i tested it with the board and all is good
i then tried to press the mode button and the remote goes mad (rapid beeping, no lights) and the beeping wouldnt stop until i turned the remote off.
when i turn it back on its fine until i press the mode button (then its the same issue)
any ideas what it is?
Did you charge it?
its not showing any lights and only starts beeping when i press the mode (will let me skate fine without pressing mode)
will try to charge though
reflash the fw, its probably bugged
have you tried taking it out of the case or loosening the screws?
yep every so often it seems to fix itself and then randomly mid ride it will come back
can you link how?
another question (yay)
weird one
12s battery
main leads measure 47v (all good)
tried charging and didnt work
charging leads measure 0.11v
do some cutting and some continuity testing and find that the lead coming out the positive and the negative lead coming out the bms measure 3v
where can i test for a bad connection and how come its giving out 3v and not 0v?
What’s the ideal way to mount a mtb top enclosure?
Looks like some people go 3-4 fasteners sideways across the center of the deck, with a spacer block (how tall?). That seems like a lot of battery weight to tip the enclosure forward and back - maybe need some compressible foam cushion underneath the edges of the enclosure?
I don’t know if there is an ideal way but the three fasteners in the middle seems to work great for me so far
The important thing is supporting enough of the center of the enclosure, and having enough screw tension to keep it from flapping too much. Bumpers on the ends would help for sure
I doubt it’s a bad connection, but rather an issue with the BMS. Either it’s damaged, or not accepting a charge for some reason.
Check all the balance wires.
Is Vestar skateboards trusted and reliable? I was thinking about purchasing parts from and wanted direct clarification from the community because there doesn’t seem to be much written up about them. Are there any parts to be careful and stay away from? Their website is Vestarboard dot com
Major question here. My board that I created has a ton of flex. I was suggested to add two more veneer layers or add carbon fiber to strengthen the board and make it stiffer. After some time i thought about it, decided to go Carbon fiber. Less the work and won’t have to sand off my precious custom graphic. So how do I do it? Can i add two layers of carbon fiber on top and call it done or there’s more of a process?
Can I charge two identical batteries each with own bms, connected in series with one brick charger at once using one charge port?
i know it works if battery is connected as parallel, not sure about series tho
shouldn’t the 2nd pack be on a different voltage range compare to the 1st pack?
But shouldn’t bms cutout them when full?
This kind ‘for sience’ doesn’t excite me
im not smart enough to know battery stuff, maybe the experts in battery club would know better
Thanks anyway
