If the motors you’re using have a high Ld-Lq then I’d not use sensors, and epoxy male (with pins, not holes) Amass MR60 connectors through the enclosure pointed slightly down (while the skate is upside down on the bench) so when you flip it over and set it on the ground they’re pointed slightly skyward from level.
Like this:
