Clean up the edges with a fine file, and wipe them down. Use black or clear silicon to screw the heatsink onto the enclosure, allowing the silicon to fill the gaps. Once it’s screwed down, you can wipe it clean, filling those extra holes.
I just got my Stormcore 60D+ and it’s using… 12awg phase leads?!? For one the bullet connectors are a size smaller than that of my TB DD, but isn’t 12awg rated at like 40 amps max?
Well, there are a lot of factors. If it’s nice high strand silicon sleeved 12 awg it should have no problem doing 60amp cont. Unless you’re gunning high speed for many miles straight, motors wont ever pull 60 amp cont. You may hit peaks much higher than 60 but 12awg can handle TB DD perfectly
i plugged in my charger (adjustable volts and amps) and it said that no current was going in (was just confirming it would charge, left it for 5 seconds in and then took it out)
battery is enclosed so getting to the p groups is a pain
Anyone got an idea what could be causing this humming sound?
This pint was repaired recently. The original burned motor connector was replaced with a mt60 phase wire connector and higo hallsensor connector. Also got a P42A pack now.
Worked fine for ~30km and then this sound appeared.
I think it sounds like some sort of resonance. The owner stripped half of the fender threads in the rails and maybe the fender resonates at certain motor rpm’s?
Dumb question but what are those rubbery doo-daas called that you use to help with cable entry into enclosure boxes? I’ve used sealants in the past but never get it looking tidy so wanted to look at some options but google not so good when you don’t know what they are called
