and also, it depends if you’re going to do wheel wells in the deck or not
I’d guess about 14mm of riser but IDK, I’d test it physically myself. You can usually get by with less riser if you make wheel wells. Like @Athrx said, take the kingpin nut and roadside bushings off and test it out. Then put it together, stand on it and lean both ways with your weight. Test ride it a bit.
