As of right now I have everything but the @moon gear drives but I am going to use the hummie hubs from my other board until I get them
I am going to hold off for a little bit before assembling this with the hubs because I plan on filming some riding clips to make a video on them to help @hummieee’s Kickstarter up in Tahoe.
I also bought an @alterbags maxi backpack for holding it while at school.
The battery is a 12s2p made of Sanyo NCR2070C with a continuous discharge of 60 amps and a capacity of 7 ah. I have had 2 batteries built from @hyperion1 and both are great and communication has been great.
I plan on doing light blue glass frit soon so I will update this when I do that.
I have a little 10s2p 30T pack that I can just bang into any board because it’s such a great size and the amp delivery is more than enough to move me around and climb moderate hills (probably more if I wanted).
I am just going to go with hummies on the haya and I might get bergs and use some at gear drives on my hummie
I am going to be down in LA with the board unless something happens on the 24 and hopefully I can join in on the skunk gang fun and I am going to be in San Diego on the 26th… can’t wait to use this and see the finished product!
The one in the picture is the charging port, that same board does not have a power switch as I rely only on push-to-start. You could do it for the power button as well, just pass a couple more wires in case you want one with light.
My other board (hb83) does have a power button (front truck) and a charging port (rear truck).
